[OpenLayers-Users] WFS-T example won't work because of error in gears_init.js line 51
Barbara Fiederer
barbara.fiederer at web.de
Wed May 27 04:08:56 EDT 2009
Hi Alexandre and Eric!
It wasn't gears_init.js. It has got something to do with the WFS I use, because the error does not occur when I delete the pieces of code related to it.
By chance I tried to open the same html-file with IE 7.0 and it worked. So, at the moment, just for testing and learning, I accept it as it is.
Thanks for your help from Barbara
>It may be that the error you're seeing in the FireBug console is
>actually unrelated to Gears. Try removing the gears_init.js entry from
>the jsfiles array in OpenLayers.js.
>Cheers,
>Eric Lemoine
> Hi Barbara,
> Have you tried to look "step-by-step" at what's going on in the code
> using firebug ? Do you see the request sent ? Do you get a response ?
> Is there a server-side error message ?
> Try to figure exactly where the error occurs by putting breakpoints.
> That might helps a lot,
> Alexandre
> Barbara Fiederer wrote:
> > Hi out there,
> > I'm new to OpenLayers, so this might be an easy problem, but I can't get it solved on my own.
> > At the moment I try to understand the examples on the OpenLayers.org-Site and to adjust them to my data. The easier ones worked out fine. But now I cannot get a WFS-T example to work. I tried two of them in the examples list of OpenLayers.org and for a last try the WFS-T Demo provided by Geoserver.
> > Two examples throw the same error in gears_init.js line 51 "factory = new ActiveXObject('Gears.Factory'); ".
> > I tried to install it, but since I do not have Autocad installed it won't work.
> > In the end I tried to copy the source text of the geoserver example, that works fine on the geoserver I use and I adjust only the pathnames to css, openLayers-Library and geodata (tasmania) on the same geoserver, but get the same error.
> > Has anyone got an idea that could help me.
> > I use FF 3.0.10, OL 2.7 on windows XP
> > Thanks, Barbara
____________________________________________________________________
Neu: WEB.DE FreeDSL Komplettanschluss mit DSL 6.000 Flatrate und
Telefonanschluss für 17,95 Euro/mtl.!* http://produkte.web.de/go/02/
