[OpenLayers-Users] WFS reprojection help
christopher.schmidt at nokia.com
Fri Jul 16 10:13:50 EDT 2010
On Jul 16, 2010, at 10:02 AM, ext Zoran Jankovic wrote:
> Hi Christopher,
> Maybe this will help: try using proj4js-compressed.js, instead of proj4js. It worked for me, when I had trouble with compatibility (IE, FF, Chrome).
Zoran:
Perfect! That did what I needed. This is what I get for skipping
setting up my own proj4js lib. I figured it was a loading issue,
but couldn't figure out what it was.
-- Chris
> BR,
> Zoran Jankovic
> ZIS-Izrada softvera i savjetovanje / ZIS - Software Development and Consulting
> http://www.zisis.hr
> M: 00 385 98 682 902
> T: 00 385 44 683 374
> A. Senoe 4
> 44320 Kutina
> Croatia
> On Fri, Jul 16, 2010 at 3:57 PM, <christopher.schmidt at nokia.com> wrote:
> On Jul 16, 2010, at 9:40 AM, ext Ian Turton wrote:
> > On Thu, Jul 15, 2010 at 10:13 PM, <christopher.schmidt at nokia.com> wrote:
> >> Hi,
> >> I have a map that I think should work at:
> >> http://crschmidt.net/mapping/mas/wfs-states.html
> >> This is a minimal modification of the wfs-states.html included in the examples.
> >> Specifically, I've added:
> >> * Proj4js lib
> >> * <script src="http://spatialreference.org/ref/epsg/26986/proj4js/"></script>
> >> And modified the layer to be a simple layer that requires reprojection.
> >> var wfs = new OpenLayers.Layer.Vector("States", {
> >> strategies: [new OpenLayers.Strategy.BBOX({ratio: 1.1})],
> >> protocol: new OpenLayers.Protocol.WFS({
> >> url: "http://giswebservices.massgis.state.ma.us/geoserver/wfs",
> >> version: '1.0.0',
> > I think you'll need to use version 1.1.0 of the WFS spec to get
> > reprojection. 1.0 only supports 4326.
> Reprojection should be working on the client side; there's an example
> of it in:
> http://openlayers.org/dev/examples/wfs-reprojection.html
> "In the case where the projection of a vector layer differs from the projection of the map, features are requested in the layer projection and transformed during parsing. It is assumed that the layer projection is "native" projection of the data (the coordinate reference system of the data on the server)."
> Additionally, though this map doesn't work in Safari when I first load
> it, when I zoom in or out, the map *does* load. (In Firefox, it doesn't
> at all.) So this seems like it's more complex than "ur doin it wrong",
> though maybe I'm still missing something obvious.
> Regards,
> Christopher Schmidt
> Nokia
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Regards,
Christopher Schmidt
Nokia
