[postgis-tickets] [PostGIS] #2501: EXTENSION in-place upgrade from 2.0 from 2.1 leaves topology procs not upgraded
PostGIS trac at osgeo.org
Wed Oct 9 00:01:08 PDT 2013
upgraded
 Reporter:  zenitram               |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.1.1
Component:  build/upgrade/install  |     Version:  2.1.x
 Keywords:                         |
Comment(by strk):
 Zenitram, which package is it, exactly ? Would you know where to file a
 ticket for packaging bugs ?
 Also, take a look at advertised version in these files (path may be
 different in your case):
 grep 'AS version'
 /usr/share/postgresql/9.1/extension/postgis_topology*--2.1.1dev.sql
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2501#comment:7>
