[postgis-tickets] [PostGIS] #2501: EXTENSION in-place upgrade from 2.0 from 2.1 leaves topology procs not upgraded
trac at osgeo.org
Wed Oct 9 03:55:08 PDT 2013
upgraded
Reporter: zenitram | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.1
Component: build/upgrade/install | Version: 2.1.x
Keywords: |
Comment(by strk):
I could actually reproduce the problem, with code from tag 2.0.3 and code
from tag 2.1.0.
Steps to reproduce:
1. create db "test", load postgis/raster/topology using 2.0.3 scripts
2. install postgis 2.1.0
3. CREATE EXTENSION postgis VERSION '2.0.3' FROM unpackaged;
4. CREATE EXTENSION postgis_topology VERSION '2.0.3' FROM unpackaged;
5. ALTER EXTENSION postgis UPDATE TO '2.1.0';
6. ALTER EXTENSION postgis_topology UPDATE TO '2.1.0';
At the end of the steps, postgis_full_version reports:
POSTGIS="2.1.0 r11822" (topology procs from "2.0.3 r11132" need upgrade)
I'll note that r11822 corresponds to tag 2.1.0 and r11132 is tag 2.0.3
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2501#comment:8>
