[postgis-tickets] [PostGIS] #2505: dumper-shp.prj: No such file or directory .. ok on bots
PostGIS trac at osgeo.org
Thu Oct 10 05:22:54 PDT 2013
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.2.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
 I'm puzzled why is it okay not to find a file?
 Both Debbie and Winnie register this line which seems really odd to me.
  dumper/literalsrid .....diff:
 /var/lib/jenkins/workspace/postgis/tmp/2_2_pg9.3w64/dumper-shp.prj: No
 .. ok
 Debbie happily moves along, but on Winnie, its followed by
 /projects/postgis/tmp/2.2.0dev_pg9.3_geos3.4.2_gdal1.10.0w64/dumper-
 .. ok
 sh:
 /projects/postgis/tmp/2.2.0dev_pg9.3_geos3.4.2_gdal1.10.0w64/test_24_tmp:
 Permission denied
 Cannot open log file
  failed (Unable to run sql script dumper/literalsrid-post.sql:
 /projects/postgis/tmp/2.2.0dev_pg9.3_geos3.4.2_gdal1.10.0w64/test_24_tmp)
 Is that a test to see if no dumper is created or to see if it is created?
 You can close it if it is by design.  I have to check permissions on
 winnie why its giving a permission denied after. Might be a test non-issue
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2505>
