[postgis-tickets] [PostGIS] #2505: dumper-shp.prj: No such file or directory .. ok on bots
trac at osgeo.org
Thu Oct 10 07:43:40 PDT 2013
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: build/upgrade/install | Version: trunk
Keywords: |
Comment(by strk):
So, dumper-shp.prj should supposedly be created by pgsql2shp. But if the
command failed you should get a failure before trying to diff. Can it be
pgsq2shp is failing to return an error code when the target directory is
read-only ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2505#comment:1>
