[postgis-tickets] [PostGIS] #2507: failing on dumper-shp.prj No such file regress test (was: bots failing on dumper-shp.prj No such file regress test)
PostGIS trac at osgeo.org
Thu Oct 10 14:04:37 PDT 2013
 Reporter:  robe       |       Owner:  robe
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.2.0
Component:  buildbots  |     Version:  2.0.x
 Keywords:             |
Comment(by robe):
 My windows 7 desktop is failing as well with similar issue.  So not just
 the bots.  I'm configured to also use custom tmp directory.  Strk can you
 try with custom folder to rule that out as the culprit.
 dumper/literalsrid ..... failed (diff expected obtained:
 /projects/postgis/tmp/2.2_pg9.3w64/test_24_diff)
 dumper/realtable ....... ok
 sh: /projects/postgis/tmp/2.2_pg9.3w64/test_25_tmp: Permission denied
 failed (Unable to run sql script dumper/realtable-post.sql:
 /projects/postgis/tmp/2.2_pg9.3w64/test_25_tmp)
 ... but cleanup sql failed! binary .. ok
 my test_24_diff just has
 diff: /projects/postgis/tmp/2.2_pg9.3w64/dumper-shp.prj: No such file or
 directory
 But the file IS THERE.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2507#comment:2>
