[postgis-tickets] [PostGIS] #2507: failing on dumper-shp.prj No such file regress test
PostGIS trac at osgeo.org
Thu Oct 10 15:32:45 PDT 2013
 Reporter:  robe       |       Owner:  robe
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.2.0
Component:  buildbots  |     Version:  2.0.x
 Keywords:             |
Comment(by robe):
 pramsey got the same error, but then his magically fixed itself after he
 cleared out his temp directory.
 I cleared mine out and also tried using default temp and still fails for
 it.
 Could it be a timing issue? Is it guaranteed they work in series that the
 dump happens and completes before your check or are they parallel jobs.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2507#comment:3>
