[postgis-tickets] [PostGIS] #2507: failing on dumper-shp.prj No such file regress test
PostGIS trac at osgeo.org
Fri Oct 11 05:37:12 PDT 2013
 Reporter:  robe       |       Owner:  robe
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.2.0
Component:  buildbots  |     Version:  2.0.x
 Keywords:             |
Comment(by robe):
 better Debbie is happy but winnie still has a problem
  /projects/postgis/tmp/2.2.0dev_pg9.3_geos3.4.2_gdal1.10.0w64/test_24_tmp:
 Permission denied
 Cannot open log file
  failed (Unable to run sql script dumper/literalsrid-post.sql:
 /projects/postgis/tmp/2.2.0dev_pg9.3_geos3.4.2_gdal1.10.0w64/test_24_tmp)
 I ran into the same issue on my windows 7 box and hoped it would go away
 when you fixed this, but it didn't.  What is this test_24_tmp it tries to
 open? I don't see one so must be some transient thing
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2507#comment:7>
