[postgis-tickets] [PostGIS] #2507: failing on dumper-shp.prj No such file regress test
trac at osgeo.org
Fri Oct 11 06:19:08 PDT 2013
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: buildbots | Version: 2.0.x
Keywords: |
Comment(by strk):
It's a temporary file where the output of an sql test is written. The 24th
test run, in this case.
You don't see why due to the Permission denied error, sounds like
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2507#comment:8>
