[postgis-tickets] [PostGIS] #2507: failing on dumper-shp.prj No such file regress test
trac at osgeo.org
Fri Oct 11 07:46:23 PDT 2013
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: buildbots | Version: 2.0.x
Keywords: |
Comment(by strk):
Can you run the tester manually and see what happens ?
regress/run_test.pl regress/dumper/literalsrid
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2507#comment:10>
