[postgis-tickets] [PostGIS] #2507: failing on dumper-shp.prj No such file regress test
PostGIS trac at osgeo.org
Fri Oct 11 23:00:02 PDT 2013
 Reporter:  robe       |       Owner:  robe
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.2.0
Component:  buildbots  |     Version:  2.0.x
 Keywords:             |
Comment(by robe):
 I ran and got this:
 regress/dumper/literalsrid ....... ok
                                       sh:
 /projects/postgis/tmp/2.2_pg9.3w64/test_1_tmp: Permission denied
 failed (Unable to run sql script regress/dumper/literalsrid-post.sql:
 /projects/postgis/tmp/2.2_pg9.3w64/test_1_tmp)
 ... but cleanup sql failed! uninstall .. ok (4112
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2507#comment:11>
