[postgis-tickets] [PostGIS] #2500: function soundex(character varying) does not exist
trac at osgeo.org
Fri Oct 11 16:21:46 PDT 2013
Reporter: mikem | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.1.1
Component: tiger geocoder | Version: 2.1.x
Resolution: worksforme | Keywords: function soundex exist
Changes (by mpaul):
* cc: mpaul (added)
* status: new => closed
* resolution: => worksforme
Comment:
I'll elaborate on robe's very useful comment.
I had the same problem, and decided to check the source code. In
postgis-2.1.0/extensions/postgis_tiger_geocoder/sql/postgis_tiger_geocoder
--2.1.0.sql , search_path is immediately set to its reset_val in
pg_settings. To find out what value is being used, do:
{{{SELECT reset_val FROM pg_settings WHERE name = 'search_path';}}}
As robe suggested, I removed my own search_path ( {{{ALTER ROLE ... RESET
search path;}}} ), changed the default search_path for the database (
{{{ALTER DATABASE ... SET search_path ... ;}}} ) to include the schema in
which I had created the fuzzystrmatch extension, logged out, logged back
in, and successfully ran:
{{{CREATE EXTENSION postgis_tiger_geocoder;}}}
In psql, you can use {{{\df soundex}}} to find the name of the schema
where fuzzystrmatch was installed. If you wish, you can {{{DROP}}} that
extension and {{{CREATE}}} it in a different schema before proceeding.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2500#comment:3>
