[postgis-tickets] [PostGIS] #2500: function soundex(character varying) does not exist
trac at osgeo.org
Tue Oct 8 06:21:31 PDT 2013
Reporter: mikem | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.1
Component: tiger geocoder | Version: 2.1.x
Keywords: function soundex exist |
Comment(by robe):
I do recall their being an issue with CREATE EXTENSION fuzzystrmatch being
installed in topology schema if you install right after topology, but
can't think of an easy way out of that.
Try installing fuzzystrmatch first.
The error usually means that where you have fuzzstrmatch is not in your
search_path
or the account you are using doesn't have rights to the installed schema.
Make sure that postgis2 is in your database search path with command
something like
ALTER DATABASE gisdb
SET search_path = "$user", postgis2, tiger_geocoder,topology;
I would avoid setting your user profile to specific search paths. That's
just asking for trouble unless you know what you are doing and can
remember that you did it for a specific role.
Do a:
ALTER ROLE michael RESET search_path;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2500#comment:2>
