[postgis-tickets] [PostGIS] #2509: dumper regress post scripts on windows getting permission denied
PostGIS trac at osgeo.org
Tue Oct 15 07:59:08 PDT 2013
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 regress/dumper/literalsrid .psql -v "VERBOSITY=terse" -tXA postgis_reg <
 regress/dumper/literalsrid-pre.sql >
 /projects/postgis/tmp/2.2_pg9.3w64/test_1_tmp 2>&1...... ok
 psql -v "VERBOSITY=terse" -tXA postgis_reg < regress/dumper/literalsr
 is/tmp/2.2_pg9.3w64/test_1_tmp: Permission denied
                                                   failed (Unable to run
 sql script regress/dumper/literalsrid-post.sql:
 /projects/postgis/tmp/2.2_pg9.3w64/test_1_tmp)
 ... but cleanup sql failed! uninstall .. ok (4112
  Run tests: 2
 this is a continuation of #2507 saga
 The actual tests past, but cleanup fails.
 As noted it that ticket PointWithSchema loader test has both a pre and
 post regress, and that passes, so not sure what is wrong with dumper
 tests.
 strk Please disable these tests if you can't fix the issue. It's a bogus
 error and preventing me from working on PostGIS 2.2
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2509>
