[postgis-tickets] [PostGIS] #2510: Remove postgis_major_version_check from postgis_upgrade_20_21.sql
trac at osgeo.org
Tue Oct 15 14:03:44 PDT 2013
Reporter: pramsey | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.1.1
Component: postgis | Version: 2.1.x
Keywords: |
Actually, it's added by the utils/postgis_proc_upgrade.pl script, that
autogenerates the upgrade script from the uninstall/install script. The
upgrade script is then copied into the EXTENSIONS area and reused for
extension scripts too. This should also apply to trunk/2.2
As it stands, the postgis_major_version_check is prevently successful use
of the "alter extension upgrade" path for packaged postgis installations,
that do not have both versions installed simultaneously (presumably our
testing didn't find this because developers frequently/always have a lot
of versions simultaneously installed)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2510>
