[postgis-tickets] [PostGIS] #2503: ERROR: table "topology" is not a member of the extension being created
trac at osgeo.org
Wed Oct 16 11:01:30 PDT 2013
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.1
Component: build/upgrade/install | Version: 2.1.x
Keywords: extension |
Comment(by robe):
I think packaging the prior unpackaged with newer is out of the question
since what is in packaged changes too much even across micros with hidden
functions. Because the unpackaged script has to include every
function/type/etc/ that was packaged with that version.
The correct way to upgrade to packaged is to
1) Upgrade without extension (to bring you up to 2.1.1 or whatever)
2) then run CREATE EXTENSION ... FROM unpackaged.
Is topology schema in your search path? I'm thinking those commands since
(topology is always going to be in topology schema) should be prefixed
with topology.
Though that brings up the question of if you ran with just CREATE
EXTENSION .. FROM unpackaged if it would run those scripts. I don't think
I have those in the unpackaged script, but probably should.
SELECT pg_catalog.pg_extension_config_dump('topology.topology', '');
SELECT pg_catalog.pg_extension_config_dump('topology.layer', '');
They are for backup so should be in run when you are going from no
extension to extension.
the reason is because the table structures are never backed up and the
data is only backed up if you have those commands.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2503#comment:7>
