[postgis-tickets] [PostGIS] #2511: geometry_columns doesn't support materialized views or foreign tables
trac at osgeo.org
Thu Oct 17 04:35:10 PDT 2013
Reporter: pramsey | Owner: pramsey
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.0.5
Component: postgis | Version: 2.0.x
Resolution: | Keywords:
Comment(by robe):
CREATE OR REPLACE VIEW geometry_columns AS
SELECT current_database()::varchar(256) AS f_table_catalog,
n.nspname::varchar(256) AS f_table_schema,
c.relname::varchar(256) AS f_table_name,
a.attname::varchar(256) AS f_geometry_column,
COALESCE(NULLIF(postgis_typmod_dims(a.atttypmod),2),
postgis_constraint_dims(n.nspname, c.relname, a.attname),
2) AS coord_dimension,
COALESCE(NULLIF(postgis_typmod_srid(a.atttypmod),0),
postgis_constraint_srid(n.nspname, c.relname, a.attname),
0) AS srid,
-- force to be uppercase with no ZM so is backwards compatible
-- with old geometry_columns
replace(
replace(
COALESCE(
NULLIF(upper(postgis_typmod_type(a.atttypmod)::text),
'GEOMETRY'),
postgis_constraint_type(n.nspname, c.relname, a.attname),
'GEOMETRY'
), 'ZM', ''
), 'Z', ''
)::varchar(30) AS type
FROM pg_class c, pg_attribute a, pg_type t, pg_namespace n
WHERE t.typname = 'geometry'::name
AND a.attisdropped = false
AND a.atttypid = t.oid
AND a.attrelid = c.oid
AND c.relnamespace = n.oid
AND (c.relkind = 'r'::"char" OR c.relkind = 'v'::"char" OR c.relkind =
'm'::"char" OR c.relkind = 'f'::"char" )
AND NOT pg_is_other_temp_schema(c.relnamespace)
AND NOT ( n.nspname = 'public' AND c.relname = 'raster_columns' )
AND has_table_privilege( c.oid, 'SELECT'::text );
above is the revised to handle foreign table wrappers. My FDW geometry
column shows up correctly with that. I would commit but not near my dev
environment and strk says I can't commit if I can't test and no counting
on bots to do my dirty work. We should probably also get rid of the
n.nspname = 'public' while we are at it, because if you install postgis in
its own schema it's slightly annoying that raster_columns appears in
geometry_columns list.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2511#comment:7>
