[postgis-tickets] [PostGIS] #2433: ST_ConcaveHull 2.1 regres failure compared to 2.0.3
PostGIS trac at osgeo.org
Fri Oct 18 16:19:31 PDT 2013
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:  PostGIS 2.1.1
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by pramsey):
 I ran the mother of all bisections and the problem stems from the C
 revision of ST_DumpPoints, at r10595. Prior that that revision it worked,
 after it, it failed with the SRID problem.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2433#comment:5>
