[postgis-tickets] [PostGIS] #2516: [raster] Debbie failing on GDAL_Trunk PostGIS regress
PostGIS trac at osgeo.org
Sat Oct 26 08:31:37 PDT 2013
 Reporter:  robe       |       Owner:  robe
     Type:  defect     |      Status:  new
 Priority:  critical   |   Milestone:  PostGIS 2.2.0
Component:  buildbots  |     Version:  trunk
 Keywords:             |
 Debbie seems to be failing now on some regress tests after GDAL trunk
 update
 http://debbie.postgis.net:8080/job/GDAL_Trunk/1115/
 GDAL SVN Revision 26554
     added DST_METHOD and support for GCP and TPS dest
     added DST_METHOD testing for GCP_POLYNOMIAL and GCP_TPS
 which changed   /trunk/gdal/alg/gdaltransformer.cpp
 The tests failing:
 Fulll ong here with errors
 http://debbie.postgis.net:8080/job/GDAL_PostGIS_Regress/1051/console
 abbreviated and a crasher at rt_setvalues_geomval_expected +psql: FATAL:
 the database system is in recovery mode
 PostgreSQL 9.2.4 on x86_64-unknown-linux-gnu, compiled by gcc (Debian
 4.4.5-8) 4.4.5, 64-bit
   Postgis 2.2.0dev - r12054 - 2013-10-26 11:22:42
   GEOS: 3.5.0dev-CAPI-1.9.0 r3883
   PROJ: Rel. 4.7.1, 23 September 2009
   GDAL: GDAL 1.11dev, released 2013/04/13
 Running tests
  check_gdal .. ok
  load_outdb ... ok
  check_raster_columns .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/gdal_regress/tmp/2_2_pg9.2w64/test_3_diff)
  check_raster_overviews .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/gdal_regress/tmp/2_2_pg9.2w64/test_4_diff)
  rt_io .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/gdal_regress/tmp/2_2_pg9.2w64/test_5_diff)
  rt_bytea .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/gdal_regress/tmp/2_2_pg9.2w64/test_6_diff)
  box3d .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/gdal_regress/tmp/2_2_pg9.2w64/test_7_diff)
  rt_addband .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/gdal_regress/tmp/2_2_pg9.2w64/test_8_diff)
  rt_band .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/gdal_regress/tmp/2_2_pg9.2w64/test_9_diff)
  rt_tile .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/gdal_regress/tmp/2_2_pg9.2w64/test_10_diff)
  rt_dimensions .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/gdal_regress/tmp/2_2_pg9.2w64/test_11_diff)
  rt_scale .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/gdal_regress/tmp/2_2_pg9.2w64/test_12_diff)
  rt_pixelsize .. ok
  rt_upperleft .. ok
  rt_rotation .. ok
  rt_georeference .. ok
  rt_set_properties .. ok
  rt_isempty .. ok
  rt_hasnoband .. ok
  rt_metadata .. ok
  rt_rastertoworldcoord .. ok
  rt_worldtorastercoord .. ok
  rt_convexhull .. ok
  rt_band_properties .. ok
  rt_set_band_properties .. ok
  rt_pixelaspolygons .. ok
  rt_pixelaspoints .. ok
  rt_pixelascentroids .. ok
  rt_setvalues_array .. ok
  rt_summarystats .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/gdal_regress/tmp/2_2_pg9.2w64/test_30_diff)
  rt_count .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/gdal_regress/tmp/2_2_pg9.2w64/test_31_diff)
  rt_histogram .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/gdal_regress/tmp/2_2_pg9.2w64/test_32_diff)
  rt_quantile .. ok
  rt_valuecount .. ok
  rt_valuepercent .. ok
  rt_bandmetadata .. ok
  rt_pixelvalue .. ok
  rt_neighborhood .. ok
  rt_nearestvalue .. ok
  rt_pixelofvalue .. ok
  rt_polygon .. ok
  rt_utility .. ok
  rt_fromgdalraster .. ok
  rt_asgdalraster .. ok
  rt_astiff .. ok
  rt_asjpeg .. ok
  rt_aspng .. ok
  rt_reclass .. ok
  rt_gdalwarp .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/gdal_regress/tmp/2_2_pg9.2w64/test_49_diff)
  rt_asraster .. ok
  rt_dumpvalues .. ok
  rt_mapalgebraexpr .. ok
  rt_mapalgebrafct .. ok
  rt_mapalgebraexpr_2raster .. ok
  rt_mapalgebrafct_2raster .. ok
  rt_mapalgebrafctngb .. ok
  rt_mapalgebrafctngb_userfunc .. ok
  rt_intersection .. ok
  rt_clip .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/gdal_regress/tmp/2_2_pg9.2w64/test_59_diff)
  rt_mapalgebra .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/gdal_regress/tmp/2_2_pg9.2w64/test_60_diff)
  rt_mapalgebra_expr .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/gdal_regress/tmp/2_2_pg9.2w64/test_61_diff)
  rt_union .. ok
  rt_invdistweight4ma .. ok
  rt_4ma .. ok
  rt_setvalues_geomval .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/gdal_regress/tmp/2_2_pg9.2w64/test_65_diff)
  rt_elevation_functions .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/gdal_regress/tmp/2_2_pg9.2w64/test_66_diff)
  rt_colormap .. ok
  rt_gist_relationships .. ok
  rt_intersects .. ok
  rt_samealignment .. ok
  rt_geos_relationships .. ok
  rt_iscoveragetile .. ok
  bug_test_car5 .. ok
  tickets .. ok
  loader/Basic .... ok
  loader/BasicCopy .... ok
  loader/BasicFilename .... ok
  loader/BasicOutDB .... ok
  loader/Tiled10x10 .... ok
  loader/Tiled10x10Copy .... ok
  loader/Tiled8x8 .... ok
  clean .. ok
  uninstall .
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2516>
