[postgis-tickets] [PostGIS] #2516: [raster] Debbie failing on GDAL_Trunk PostGIS regress
PostGIS trac at osgeo.org
Sat Oct 26 08:32:46 PDT 2013
 Reporter:  robe      |       Owner:  dustymugs
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  PostGIS 2.2.0
Component:  raster    |     Version:  trunk
 Keywords:            |
Comment(by robe):
 Dusty or Pierre,
 When you get a chance, can you try build PostGIS with latest GDAL.  I'll
 try to do that locally but not setup to at moment, to rule this out as
 just a bot issue.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2516#comment:2>
