[postgis-tickets] [PostGIS] #2522: parse_address('16 Berry Lane, skenectady, ny 12302') is wrong
PostGIS trac at osgeo.org
Wed Oct 30 17:26:54 PDT 2013
 Reporter:  woodbri              |       Owner:  robe
     Type:  defect               |      Status:  new
 Priority:  medium               |   Milestone:  PostGIS 2.1.1
Component:  pagc_address_parser  |     Version:  2.1.x
 Keywords:                       |
Comment(by woodbri):
 Yes, that is the right thing to do.
 I thought we were already using that package, but maybe not. The perl
 package changed names when the author refactored it. It turns out that
 then new package is not not compatible with pcre that is used in the C
 code and I had to modify the generated regexp strings so they worked with
 pcre.
 I created a test file as I mentioned, it might be nice if that could be
 turned into postgis test in some way. My plan is to expand on the tests
 over time, but the current file tests that the high level parsing patterns
 all work at least at a superficial level.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2522#comment:5>
