[postgis-tickets] [PostGIS] #2843: [raster] Support reprojection on import
trac at osgeo.org
Fri Jul 18 03:02:08 PDT 2014
Reporter: strk | Owner: dustymugs
Type: enhancement | Status: reopened
Priority: medium | Milestone: PostGIS 2.2.0
Component: raster | Version: trunk
Resolution: | Keywords: history
Changes (by strk):
* status: closed => reopened
* resolution: fixed =>
Comment:
I'm reopening this because in-db reprojection is very limited.
The main 2 limits are:
1. Tiled output can result in different tiles using different scales
(easy, if you come from 4326 and project to webmercator/3857)
2. You cannot use COPY mode (-Y)
Ideally the transformation would be done via GDAL instead.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2843#comment:2>
