[postgis-tickets] [PostGIS] #1014: GEOMETRY type is not "hashable"
trac at osgeo.org
Fri Jul 3 08:14:35 PDT 2015
Reporter: vince | Owner: pramsey
Type: enhancement | Status: reopened
Priority: medium | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Resolution: | Keywords: GEOMETRY hash UNION
Changes (by pramsey):
* status: closed => reopened
* resolution: wontfix =>
* version: 1.5.X => trunk
* type: defect => enhancement
* milestone: PostGIS 1.5.3 => PostGIS 2.2.0
Comment:
I'm finding it hard to care about the issue mentioned in Mark's article.
Basically, if I'm reading it right, it means that our hashing would
provide a different value for:
POINT(0 0) and POINT(-0 0)
So if you tried to test equality with the hash function, you'd be told
they aren't equal. And if you did a SELECT 'POINT(0 0)' UNION SELECT
POINT(-0 0) you'd get back two rows instead of one.
This seems like hardly a deathly issue, and I being too cowboy here? We're
already consuming POINT(NaN NaN) for infrastructural purposes, and not
allowing convenient CTE recursion (in all cases) because we might
accidentally duplicate 0 and -0 cases? Seem like nose cutting and face
spiting.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1014#comment:11>
