[postgis-tickets] [PostGIS] #3197: SQL function for GEOSEqualsExact
PostGIS trac at osgeo.org
Thu Jul 9 01:06:04 PDT 2015
 Reporter:  mwtoews      |      Owner:  pramsey
     Type:  enhancement  |     Status:  new
 Priority:  medium       |  Milestone:  PostGIS Future
Component:  postgis      |    Version:
 Keywords:               |
 This enhancement request is to add an SQL function to access
 GEOSEqualsExact from the GEOS C API to find geometries that are equal, up
 to a specified tolerance. A suggested prototype would be:
     boolean ST_EqualsExact(geometry A, geometry B, integer tolerance
 DEFAULT 6);
 Although a name ST_AlmostEquals might better describe the desired
 operation, since it is designed to provide equality for inexact
 geometries.
 External to GEOS, it is used in Shapely as
 [http://toblerity.org/shapely/manual.html#object.almost_equals
 object.almost_equals](other[, decimal=6])
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3197>
