[postgis-tickets] [PostGIS] #3174: unit test for lwgeom_mindistance2d_tolerance
PostGIS trac at osgeo.org
Mon Jul 13 14:47:57 PDT 2015
  Reporter:  strk         |      Owner:  nicklas
      Type:  enhancement  |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS Future
 Component:  liblwgeom    |    Version:  trunk
Resolution:               |   Keywords:
Comment (by nicklas):
 I don't really get this request.
 lwgeom_mindistance2d_tolerance is just an internal function with a bad
 name.
 raising the tolerance above 0 will stop the calculations to save some cpu-
 cycles.
 But the logic of ST_DWithin is done on the outer function LWGEOM_dwithin.
 Testing if the function stops as expected I can understand, but the result
 will change with small changes in code without changing output.
 But where to document it? and for who?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3174#comment:1>
