[postgis-tickets] [PostGIS] #2429: Curve lost in conversion
PostGIS trac at osgeo.org
Tue Jul 14 14:12:44 PDT 2015
  Reporter:  strk     |      Owner:  strk
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.2.0
 Component:  postgis  |    Version:  2.0.x
Resolution:           |   Keywords:  curves
Comment (by pramsey):
 The patch above both loosens the tolerances a bit as you suggest and also
 evens up the output segments produced during stroking, to reduce the
 variability of radius and angle in the output (allowing the unstroke to
 succeed more often).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2429#comment:7>
