[postgis-tickets] [PostGIS] #2278: make liblwgeom compatible between micro releases
trac at osgeo.org
Wed Jul 15 23:24:34 PDT 2015
Reporter: mwanner | Owner: strk
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.2.0
Component: liblwgeom | Version: 2.0.x
Resolution: | Keywords:
Changes (by robe):
* priority: low => high
* type: enhancement => defect
* milestone: PostGIS Future => PostGIS 2.2.0
Comment:
I know we said only bug fixes in 2.2 after feature freeze call, but I
proclaim this to be a bug and not only do I want patch level
compatibility, I want the name to be consistent with the rest of PostGIS
proper (which means no micro taked on to the end of the .so/.dll file).
Actually that part is more important to me.
First of all, now that I've got this extra liblwgeom*.dll following me
around in 2.2 (and my shp2pgsql-qui, shp2pgsql, pgsql2shp now depend on
it), to add insult to injury, it has the nerve to tack on a micro on the
name so it's liblwgeom-2.2.0dev.dll in 2.2.0dev. This was not the case in
2.1 for me. So this is a PITA for (at least for windows distribution, I
imagine for others as well) since old cruft is left behind when people
upgrade to a micro. If liblwgeom is going to be shared, then its got to
have the same version .so/dll name as PostGIS proper (which means NO
.micro at the end)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2278#comment:12>
