[postgis-tickets] [PostGIS] #3220: Mingw failure on cluster test
trac at osgeo.org
Thu Jul 30 16:57:54 PDT 2015
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Keywords: |
I'm getting this failure only under mingw, for some reason regress testing
against VC++ doesn't error out (well last I tried it didn't anyway, I'll
retry to confirm), which explains why winnie is probably not complaining
about this.
It looks like it might be just some sort of ordering difference since all
the values are there, but in my mingw it comes in as a single geometry
collection and regress expected looks like two geometry collections with
polygon:
GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))
coming in via a separate geometry collection.
Anyway I have to upgrade to 9.4.4 anyway. Though my 9.5dev fails in same
spot I think.
I also notice I am running a slightly older GEOS 3.5 than winnie so could
be caused by that too. Will close this out if that is the case.
PostgreSQL 9.4.1 on x86_64-w64-mingw32, compiled by gcc.exe (x86_64-win32
-seh-rev1, Built by MinGW-W64 project) 4.8.3, 64-bit
Postgis 2.2.0dev - r13860 - 2015-07-30 23:48:27
scripts 2.2.0dev r13860
GEOS: 3.5.0dev-CAPI-1.9.0 r4034
PROJ: Rel. 4.9.1, 04 March 2015
SFCGAL: 1.1.0
--- cluster_expected 2015-07-30 14:50:49 -0400
+++ /projects/postgis/tmp/2.2_pg9.4w64/test_31_out 2015-07-30
18:37:21 -0400
@@ -4,8 +4,7 @@
t2|GEOMETRYCOLLECTION(LINESTRING(0 0,1 1),LINESTRING(5 5,4
4),LINESTRING(0 0,-1 -1),POLYGON((0 0,4 0,4 4,0 4,0 0)))
t2|GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))
t2|GEOMETRYCOLLECTION(POLYGON EMPTY)
-t3|GEOMETRYCOLLECTION(LINESTRING(0 0,1 1),LINESTRING(5 5,4
-t3|GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))
+t3|GEOMETRYCOLLECTION(LINESTRING(0 0,1 1),LINESTRING(5 5,4
4),LINESTRING(0 0,-1 -1),LINESTRING(6 6,7 7),POLYGON((0 0,4 0,4 4,0 4,0
0)))
t3|GEOMETRYCOLLECTION(POLYGON EMPTY)
t4|GEOMETRYCOLLECTION(LINESTRING(0 0,1 1),LINESTRING(5 5,4
0)))
t4|GEOMETRYCOLLECTION(POLYGON EMPTY)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3220>
