[postgis-tickets] [PostGIS] #3335: Handle parallel make properly
trac at osgeo.org
Fri Oct 16 22:35:26 PDT 2015
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.0
Component: build/upgrade/install | Version: trunk
Keywords: |
I've seen this come up a number of times on IRC and once on mailing list:
https://lists.osgeo.org/pipermail/postgis-devel/2015-October/025368.html
I did note that the resulting makefiles are incomplete, and I have to
compile with 'make -j1' rather than the usual (for my build system)
'make -j12'.
Where people's make defaults to parallel build, and then PostGIS compile
fails with a cryptic error I think about raster. I can't find the irc log
entries where someone provided the error.
Is ther something we can do about this to either automatically disable
this or allow it without error.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3335>
