[postgis-tickets] [PostGIS] #3340: populate_geometry_columns does not work on foreign tables
trac at osgeo.org
Sun Oct 18 19:40:39 PDT 2015
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.1
Component: postgis | Version: 2.2.x
Keywords: |
I was playing around with 9.5 trying to get my foreign tiger tables to
inherit from my local tiger schema and ran into an issue that when you set
a foreign table to inherit from a local one, it doesn't add on the
constraints and fails because the foreign table came in with no
constraints.
Anyway I thought I could solve this by using
SELECT populate_geometry_columns(false);
Nope - our populate_geometry_columns has never heard of foreign tables and
just skips over them. I'm testing out my patch before I commit, but would
like to get it in for 2.2.1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3340>
