[postgis-tickets] [PostGIS] #3547: Update to support Tiger 2016
trac at osgeo.org
Wed Aug 17 12:31:35 PDT 2016
Reporter: robe | Owner: robe
Type: defect | Status: closed
Priority: critical | Milestone: PostGIS 2.3.0
Component: tiger geocoder | Version: trunk
Resolution: fixed | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"15045" 15045]:
#!CommitTicketReference repository="" revision="15045"
Also revise scripts to support both http and ftp, change url to use http:
Update docs with more help for Linux/Unix folks, revise paths to more
closely mirror ubuntu and use 9.6
Add note about BRIN, parallel, and TIGER 2016 in what is new section
Closes #3547
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3547#comment:3>
