[postgis-tickets] r14612 - #3433, ST_ClusterIntersecting gives incorrect result for MultiPoints
Daniel Baston
dbaston at gmail.com
Wed Jan 20 04:18:14 PST 2016
Author: dbaston
Date: 2016-01-20 04:18:14 -0800 (Wed, 20 Jan 2016)
New Revision: 14612
branches/2.2/NEWS
branches/2.2/liblwgeom/cunit/cu_geos_cluster.c
branches/2.2/liblwgeom/lwgeom_geos_cluster.c
Modified: branches/2.2/NEWS
--- branches/2.2/NEWS 2016-01-20 11:57:21 UTC (rev 14611)
+++ branches/2.2/NEWS 2016-01-20 12:18:14 UTC (rev 14612)
@@ -6,6 +6,7 @@
- #3422, Improve ST_Split robustness on standard precision double
systems (arm64, ppc64el, s390c, powerpc, ...)
- #3427, Update spatial_ref_sys to EPSG version 8.8
+ - #3433, ST_ClusterIntersecting incorrect for MultiPoints
- #3436, memory handling mistake in ptarray_clone_deep
PostGIS 2.2.1
Modified: branches/2.2/liblwgeom/cunit/cu_geos_cluster.c
--- branches/2.2/liblwgeom/cunit/cu_geos_cluster.c 2016-01-20 11:57:21 UTC (rev 14611)
+++ branches/2.2/liblwgeom/cunit/cu_geos_cluster.c 2016-01-20 12:18:14 UTC (rev 14612)
@@ -238,6 +238,23 @@
perform_cluster_within_distance_test(1, wkt_inputs, 2, expected_outputs, 2);
+static void multipoint_test(void)
+ /* See #3433 */
+ char* wkt_inputs_mp[] = { "MULTIPOINT ((0 0), (0 1))", "POINT (0 0)"};
+ char* expected_outputs_mp[] = { "GEOMETRYCOLLECTION(MULTIPOINT ((0 0), (0 1)), POINT (0 0))"};
+ char* wkt_inputs_gc[] = { "GEOMETRYCOLLECTION (POINT (0 0), POINT (0 1))", "POINT (0 0)"};
+ char* expected_outputs_gc[] = { "GEOMETRYCOLLECTION(GEOMETRYCOLLECTION (POINT (0 0), POINT (0 1)), POINT (0 0))"};
+ char* wkt_inputs_pt[] = { "POINT (3 3)", "POINT (3 3)"};
+ char* expected_outputs_pt[] = { "GEOMETRYCOLLECTION(POINT (3 3), POINT (3 3))"};
+ perform_cluster_intersecting_test(wkt_inputs_mp, 2, expected_outputs_mp, 1);
+ perform_cluster_intersecting_test(wkt_inputs_gc, 2, expected_outputs_gc, 1);
+ perform_cluster_intersecting_test(wkt_inputs_pt, 2, expected_outputs_pt, 1);
void geos_cluster_suite_setup(void);
@@ -247,4 +264,5 @@
PG_ADD_TEST(suite, basic_distance_test);
PG_ADD_TEST(suite, single_input_test);
PG_ADD_TEST(suite, empty_inputs_test);
+ PG_ADD_TEST(suite, multipoint_test);
Modified: branches/2.2/liblwgeom/lwgeom_geos_cluster.c
--- branches/2.2/liblwgeom/lwgeom_geos_cluster.c 2016-01-20 11:57:21 UTC (rev 14611)
+++ branches/2.2/liblwgeom/lwgeom_geos_cluster.c 2016-01-20 12:18:14 UTC (rev 14612)
@@ -124,12 +124,26 @@
if (p != q && UF_find(cxt->uf, p) != UF_find(cxt->uf, q))
- /* Lazy initialize prepared geometry */
- if (cxt->prep == NULL)
+ int geos_type = GEOSGeomTypeId(cxt->geoms[p]);
+ int geos_result;
+ /* Don't build prepared a geometry around a Point or MultiPoint -
+ * there are some problems in the implementation, and it's not clear
+ * there would be a performance benefit in any case. (See #3433)
+ if (geos_type != GEOS_POINT && geos_type != GEOS_MULTIPOINT)
- cxt->prep = GEOSPrepare(cxt->geoms[p]);
+ /* Lazy initialize prepared geometry */
+ if (cxt->prep == NULL)
+ cxt->prep = GEOSPrepare(cxt->geoms[p]);
+ geos_result = GEOSPreparedIntersects(cxt->prep, cxt->geoms[q]);
- int geos_result = GEOSPreparedIntersects(cxt->prep, cxt->geoms[q]);
+ else
+ geos_result = GEOSIntersects(cxt->geoms[p], cxt->geoms[q]);
if (geos_result > 1)
cxt->error = geos_result;
