[postgis-tickets] [PostGIS] #3384: Patch up docs reflect 9.1 is not supported in 2.3
trac at osgeo.org
Sat Jul 30 21:29:30 PDT 2016
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.0
Component: documentation | Version: trunk
Resolution: | Keywords:
Description changed by robe:
Old description:
> Since PostgreSQL 9.1, is going to reach EOL probably before 2.3 release,
> it's time to kill it as noted in
> https://lists.osgeo.org/pipermail/postgis-devel/2015-November/025480.html
> Couple of things need changing, some for 2.2 as well
> 1) our header in docs says if compiling with less than 9.1 (that header
> should be changed to compiling without raster support) since now it's
> only relevant if you are compiling without raster support or you for
> whatever reason want to use scripts.
> http://postgis.net/docs/manual-2.2/postgis_installation.html#create_new_db
> This should really read without extension support (no raster)
> So it's clearer to folks installing wo raster that they need to use these
> instructions.
> 2) Need to update minimum requirements in docs
> We should start looking thru our code, to see what stuff we can leverage
> that is only supported in 9.2+ and take out any ifDEF stuff targetting <
> 9.2. That can be saved for later as a separate ticket.
New description:
should be changed to compiling without raster support) since now it's only
relevant if you are compiling without raster support or you for whatever
instructions.
3) Also change our configure to not allow compiling against lower than
PostgreSQL 9.2, because backend guc stuff and raster gets pretty nasty on
9.1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3384#comment:2>
