[postgis-tickets] r15238 - Change MSG line
Paul Ramsey
pramsey at cleverelephant.ca
Mon Nov 21 07:03:33 PST 2016
Author: pramsey
Date: 2016-11-21 07:03:33 -0800 (Mon, 21 Nov 2016)
New Revision: 15238
branches/2.3/configure.ac
Change MSG line
Modified: branches/2.3/configure.ac
--- branches/2.3/configure.ac 2016-11-21 15:03:20 UTC (rev 15237)
+++ branches/2.3/configure.ac 2016-11-21 15:03:33 UTC (rev 15238)
@@ -574,15 +574,15 @@
darwin*)
AC_PATH_PROG([XCRUN], [xcrun])
if test "x$XCRUN" = "x"; then
- AC_MSG_RESULT([using OSX XCode... yes])
+ AC_MSG_RESULT([using OSX XCode... no])
else
- XCODE_VER=`$XCRUN --show-sdk-version`
- if test $XCODE_VER = "10.12"; then
- AC_MSG_RESULT([applying OSX XCode 10.12 libxml special case... yes])
- XML2_LDFLAGS=`$XML2CONFIG --exec-prefix=/usr --libs`
- else
- AC_MSG_RESULT([using OSX XCode $XCODE_VER... yes])
- fi
+ XCODE_VER=`$XCRUN --show-sdk-version`
+ if test $XCODE_VER = "10.12"; then
+ AC_MSG_RESULT([applying OSX XCode 10.12 libxml special case... yes])
+ XML2_LDFLAGS=`$XML2CONFIG --exec-prefix=/usr --libs`
+ else
+ AC_MSG_RESULT([using OSX XCode $XCODE_VER... yes])
+ fi
fi
esac
