[postgis-tickets] [PostGIS] #3698: CENSUS Download path for TABBLOCK
trac at osgeo.org
Tue Aug 15 07:45:14 PDT 2017
Reporter: EvanCarroll | Owner: robe
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.3.4
Component: tiger geocoder | Version: 2.3.x
Resolution: | Keywords:
Comment (by jeffreywescott):
So, any recommendations for someone like me who has a use case that ''does
require'' census block data?
In the generated {{{load-states.sh}}} script I tried appending the
filename references like so:
sed -i "s/_tabblock\./_tabblock10./g" load-states.sh
That seemed to get it to work. However, when I try to load a state (e.g.,
{{{'CA'}}}), there are still no rows in the {{{tabblocks}}} table:
postgres=# select * from tabblock;
gid | statefp | countyfp | tractce | blockce | tabblock_id | name | mtfcc
| ur | uace | funcstat | aland | awater | intptlat | intptlon | the_geom
(0 rows)
I noticed that for most other tables, {{{loader_load_staged_data}}} is
used to transfer the data from the {{{tiger_staging}}} to the
{{{tiger_data}}} database, but that doesn't seem to be happening for the
{{{tabblock}}} table in the script. Notice the difference between the
{{{CA_tract}}} and {{{CA_tabblock}}} handling from the script excerpt
below:
${PSQL} -c "CREATE TABLE tiger_data.CA_tract(CONSTRAINT pk_CA_tract
PRIMARY KEY (tract_id) ) INHERITS(tiger.tract); "
${SHP2PGSQL} -D -c -s 4269 -g the_geom -W "latin1" tl_2013_06_tract.dbf
tiger_staging.ca_tract | ${PSQL}
${PSQL} -c "ALTER TABLE tiger_staging.CA_tract RENAME geoid TO tract_id;
SELECT loader_load_staged_data(lower('CA_tract'), lower('CA_tract')); "
${PSQL} -c "CREATE INDEX tiger_data_CA_tract_the_geom_gist ON
tiger_data.CA_tract USING gist(the_geom);"
${PSQL} -c "VACUUM ANALYZE tiger_data.CA_tract;"
${PSQL} -c "ALTER TABLE tiger_data.CA_tract ADD CONSTRAINT
chk_statefp CHECK (statefp = '06');"
cd /gisdata
#wget
http://www2.census.gov/geo/tiger/TIGER2013/TABBLOCK/tl_2013_06_tabblock.zip
--mirror --reject=html
cd /gisdata/www2.census.gov/geo/tiger/TIGER2013/TABBLOCK
rm -f ${TMPDIR}/*.*
${PSQL} -c "DROP SCHEMA IF EXISTS tiger_staging CASCADE;"
${PSQL} -c "CREATE SCHEMA tiger_staging;"
for z in tl_2013_06*_tabblock.zip ; do $UNZIPTOOL -o -d $TMPDIR $z; done
cd $TMPDIR;
${PSQL} -c "CREATE TABLE tiger_data.CA_tabblock(CONSTRAINT pk_CA_tabblock
PRIMARY KEY (tabblock_id)) INHERITS(tiger.tabblock);"
tl_2013_06_tabblock.dbf tiger_staging.ca_tabblock | ${PSQL}
${PSQL} -c "ALTER TABLE tiger_staging.CA_tabblock RENAME geoid TO
tabblock_id;"
${PSQL} -c "ALTER TABLE tiger_data.CA_tabblock ADD CONSTRAINT chk_statefp
${PSQL} -c "CREATE INDEX tiger_data_CA_tabblock_the_geom_gist ON
tiger_data.CA_tabblock USING gist(the_geom);"
${PSQL} -c "vacuum analyze tiger_data.CA_tabblock;"
cd /gisdata
#wget http://www2.census.gov/geo/tiger/TIGER2013/BG/tl_2013_06_bg.zip
cd /gisdata/www2.census.gov/geo/tiger/TIGER2013/BG
rm -f ${TMPDIR}/*.*
for z in tl_2013_06*_bg.zip ; do $UNZIPTOOL -o -d $TMPDIR $z; done
cd $TMPDIR;
Any ideas on how to make sure my {{{tabblock}}} table gets populated using
the TIGER2016 data?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3698#comment:12>
