[postgis-tickets] [PostGIS] #3809: Add ST_DistanceIndexed function
trac at osgeo.org
Fri Aug 25 06:01:54 PDT 2017
Reporter: dbaston | Owner: pramsey
Type: enhancement | Status: new
Priority: blocker | Milestone: PostGIS 2.4.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by dbaston):
The indexed distance calculations in GEOS use a particular definition of
"distance." From the JTS docs:
> Distances will be computed to all facets of the input geometry. The
facets of the geometry are the discrete segments and points contained in
its components. In the case of Lineal and Puntal inputs, this is
equivalent to computing the conventional distance. In the case of
Polygonal inputs, this is equivalent to computing the distance to the
polygons boundaries.
When one polygon is entirely contained within another polygon, the
distance between them is greater than zero.
I think this functionality is valuable in PostGIS, but the name
{{{ST_DistanceIndexed}}} risks creating confusion.
Is one of these options better?
* ST_LinearDistanceIndexed
* ST_BoundaryDistanceIndexed
* ST_IndexedFacetDistance (the JTS name)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3809#comment:2>
