[postgis-tickets] [PostGIS] #3706: Use of deprecated function
PostGIS trac at osgeo.org
Wed Dec 20 21:19:29 PST 2017
  Reporter:  postgispaul  |      Owner:  robe
      Type:  defect       |     Status:  closed
  Priority:  high         |  Milestone:  PostGIS 2.3.3
 Component:  postgis      |    Version:  2.3.x
Resolution:  worksforme   |   Keywords:
Comment (by robe):
 What are you using for viewing.  In pgAdmin the aggregates show under
 aggregates section, not functions.
 What are you upgrading from.
 And you did the
 ALTER EXTENSION postgis UPDATE;
 dance for sure?
 What does:
 SELECT postgis_full_version();
 return for you?
 There is a trick to force aggregates to upgrade.  I think aggregates and
 types are the only things we rely the update message to know whether to
 upgrade or not because they could destroy user created things.  Functions
 are always recreated, so they should all be fine.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3706#comment:5>
