[postgis-tickets] [PostGIS] #3962: debbie trunk (2.5 builds failing) for 9.6 and 9.5
PostGIS trac at osgeo.org
Wed Dec 27 10:29:12 PST 2017
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 2.5.0
 Component:  buildbots  |    Version:  trunk
Resolution:             |   Keywords:
Comment (by robe):
 okay answer just came to me.  I recalled strk added a Drop postgis_reg
 database command to trunk recent.  I think that may be what's causing the
 problem.
 I added a sleep 5 to the postgis regress and so far so good.  Maybe in
 past since there was no pre-drop the postgres instance had just enough
 time to get ready for connections, before the tests started.  Perhaps 11
 and 10 just start up faster.
 2.4 wouldn't have the issue since I don't think strk back-ported the
 change.
 I'll close as soon as I have confirmed the sleep call does the trick.  I
 maybe should just put this as part of regress script instead of hard-
 coding in the PostGIS_Regress job.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3962#comment:1>
