[postgis-tickets] [PostGIS] #3702: ST_LineToCurve not working as documented
PostGIS trac at osgeo.org
Fri Feb 3 01:27:48 PST 2017
 Reporter:  mkuhn    |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 2.3.3
Component:  postgis  |    Version:  2.3.x
 Keywords:           |
 The examples from the postgis documentation and the result of my local
 installation do not behave the same way.
 Documentation says:
 -- 3D example
 SELECT ST_AsEWKT(ST_LineToCurve(ST_GeomFromEWKT('LINESTRING(1 2 3, 3 4 8,
 5 6 4, 7 8 4, 9 10 4)')));
                          st_asewkt
  CIRCULARSTRING(1 2 3,5 6 4,9 10 4)
 My local installation does:
 -- 3D example
                          st_asewkt
 "LINESTRING(1 2 3,3 4 8,5 6 4,7 8 4,9 10 4)"
 SELECT postgis_version()
 "2.3 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"
 Am I misunderstanding something?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3702>
