[postgis-tickets] [PostGIS] #3661: Mapbox vector tile output support via ST_AsMVT
trac at osgeo.org
Tue Feb 7 08:02:29 PST 2017
Reporter: Björn Harrtell | Owner: robe
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.4.0
Component: postgis | Version: trunk
Resolution: | Keywords: history, mvt
Comment (by robe):
Thanks
I've installed:
apt-get install protobuf-compiler
I'll rerun the job in a bit.
For windows (to install on winnie), I'm building that from scratch.
So far I have the below compiled and installed
and Protobuf - 3.2.0 - https://github.com/google/protobuf
Protobuf-c v. 1.2.1 https://github.com/protobuf-c/protobuf-c
anything else I need, I haven't started to compile yet.
Does the PROTOBUFDIR configure variable assume that both protobuf and
protobuf-c are installed in the same folder. Out of habit I installed
them in separate folders.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3661#comment:14>
