[postgis-tickets] r15309 - Fix typo
Sandro Santilli strk at kbt.io
Thu Feb 9 00:29:47 PST 2017
Author: strk
Date: 2017-02-09 00:29:47 -0800 (Thu, 09 Feb 2017)
New Revision: 15309
   trunk/doc/reference_processing.xml
Fix typo
Thanks Anton Bobov (https://github.com/postgis/postgis/pull/124)
Modified: trunk/doc/reference_processing.xml
--- trunk/doc/reference_processing.xml	2017-02-08 13:25:12 UTC (rev 15308)
+++ trunk/doc/reference_processing.xml	2017-02-09 08:29:47 UTC (rev 15309)
@@ -100,7 +100,7 @@
 				<para>&sqlmm_compliant; SQL-MM 3: 5.1.17</para>
 				<note><para>People often make the mistake of using this function to try to do radius searches.  Creating a
-					buffer to to a radius search is slow and pointless.  Use <xref linkend="ST_DWithin" /> instead.</para></note>
+					buffer to a radius search is slow and pointless.  Use <xref linkend="ST_DWithin" /> instead.</para></note>
 			</refsection>
 			  <refsection>
