[postgis-tickets] r15308 - Add notes about dependency requirements for ST_AsMVT
Sandro Santilli
strk at kbt.io
Wed Feb 8 05:25:13 PST 2017
Author: strk
Date: 2017-02-08 05:25:12 -0800 (Wed, 08 Feb 2017)
New Revision: 15308
trunk/doc/installation.xml
Patch by Bj?\195?\182rn Harrtell <bjorn at wololo.org>
Modified: trunk/doc/installation.xml
--- trunk/doc/installation.xml 2017-02-07 21:42:32 UTC (rev 15307)
+++ trunk/doc/installation.xml 2017-02-08 13:25:12 UTC (rev 15308)
@@ -206,6 +206,14 @@
</para>
</listitem>
+ <listitem>
+ <para>
+ To enable ST_AsMVT protobuf-c library (for usage) and the protoc-c compiler (for building) are required.
+ Also, pgk-config is required to verify the correct minimum version of protobuf-c.
+ See <ulink url="https://github.com/protobuf-c/protobuf-c">protobuf-c</ulink>.
+ </para>
+ </listitem>
<listitem>
<para>
CUnit (<filename>CUnit</filename>). This is needed for regression testing. <ulink url="http://cunit.sourceforge.net/">http://cunit.sourceforge.net/</ulink>
