[postgis-tickets] [PostGIS] #3716: Gist index irrational growth
trac at osgeo.org
Mon Feb 20 06:36:12 PST 2017
Reporter: Marcin Piotrowski | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 2.1.x
Keywords: |
etry column).
The size was not shrinked during autovacuum, only full vacuum was able to
free the disk space.
This is reproducable using following example that inserts 10000 rows and
performs 1000 updates on the status column. After that index size is 321
MB
(321 MB of indexed nulls ! )
-- psql script to create the database
CREATE DATABASE gist_weirdness WITH TEMPLATE = template0 ENCODING = 'UTF8'
LC_COLLATE = 'en_US.utf8' LC_CTYPE = 'en_US.utf8';
\connect gist_weirdness
CREATE EXTENSION IF NOT EXISTS plpgsql WITH SCHEMA pg_catalog;
CREATE EXTENSION IF NOT EXISTS postgis WITH SCHEMA public;
CREATE TABLE table_with_gist (
id integer NOT NULL,
status character varying(10),
geompolygon geometry(Polygon,4326)
CREATE SEQUENCE table_with_gist_id_seq
START WITH 1
INCREMENT BY 1
NO MINVALUE
NO MAXVALUE
CACHE 1;
ALTER TABLE ONLY table_with_gist ALTER COLUMN id SET DEFAULT
nextval('table_with_gist_id_seq'::regclass);
CREATE INDEX incidents_geompolygon_idx ON table_with_gist USING gist
(geompolygon);
-- pgscript to insert data
DECLARE @I;
set @I = 0;
while @I < 10000
begin
INSERT INTO table_with_gist(status) VALUES (cast (@I as CHARACTER
VARYING));
set @I = @I + 1;
end
--pgscript to update data
DECLARE @I;
set @I = 0;
while @I < 1000
begin
update table_with_gist set status=status::integer+7;
set @I = @I + 1;
end
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3716>
