[postgis-tickets] [PostGIS] #3712: Address MVT issues reported by specification author
trac at osgeo.org
Mon Feb 20 08:36:09 PST 2017
Reporter: strk | Owner: Björn Harrtell
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.4.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by flippmoke):
I would be interested if it is faster for you all to check validity and
then correct if needed or if always running the validity correction was
faster. I would suggest not turning off validity checks/correction with a
flag as users, I would suggest limiting options as it would be difficult
to explain for users how to properly use the method.
Also as per my previous conversation about adding a srs, I would assume
you would default it to 4326 and only if they passed something different
it would change.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3712#comment:9>
