[postgis-tickets] [PostGIS] #3717: geocode_intersection documentation has wrong parameter name for maximum results returned
PostGIS trac at osgeo.org
Mon Feb 20 19:41:14 PST 2017
results returned
 Reporter:  znmeb                   |      Owner:  robe
     Type:  defect                  |     Status:  new
 Priority:  medium                  |  Milestone:  PostGIS 2.3.3
Component:  documentation           |    Version:  2.3.x
 Keywords:  geocoder, intersection  |
 The documentation for geocode_intersection specifies the maximum number of
 results returned by the name "max_results".
 (http://postgis.net/docs/Geocode_Intersection.html). However, the
 parameter name in the function definition is "num_results". See attached
 screenshot from PgAdmin4.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3717>
