[postgis-tickets] [PostGIS] #3712: Address MVT issues reported by specification author
PostGIS trac at osgeo.org
Tue Feb 21 05:39:30 PST 2017
  Reporter:  strk     |      Owner:  Björn Harrtell
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by robe):
 ST_MakeValid does not always produce useful output (or at least useful to
 the user, for example it could turn a polygon into a linestring if it
 can't make a valid polygon wihout loosing points) all the time and as a
 general rule. None of our output functions try to make anything valid.
 That's the user's responsibility.  So I think just checking correctness
 and throwing an error if you think it's unacceptable to output, or just a
 warning notice is good enough.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3712#comment:11>
