[postgis-tickets] [PostGIS] #3722: ST_ASMVT regress on PostgreSQL 10
PostGIS trac at osgeo.org
Mon Feb 27 13:03:26 PST 2017
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 2.4.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 Bjorn,
 I guess you can't easily check this until we have PostgreSQL 10 at least
 being able to compile PostGIS, as a result of #3271.
 But here it goes, Debbie's last run in 10.0.  MVT is just one of other
 problems with have with 10.0.
  mvt .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_4_pg10.0w64/test_119_diff)
 --- mvt_expected        2017-02-06 16:48:10.479047203 +0000
 /var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_4_pg10.0w64/test_119_out
 2017-02-23 20:05:58.050464234 +0000
 @@ -14,7 +14,7 @@
  TA4|GjAKBHRlc3QSDBICAAAYASIECTLePxIMEgIAARgBIgQJMt4/GgJjMSICIAEiAiACeAI=
  TA5|GiwKBHRlc3QSDhIEAAABARgBIgQJMt4/GgJjMRoCYzIiAiABIgYKBGFiY2R4Ag==
  TU1
 -ERROR:  could not determine polymorphic type because input has type
 "unknown"
 +ERROR:  could not determine polymorphic type because input has type
 unknown
  TU2
  ERROR:  pgis_asmvt_transfn: parameter row cannot be other than a rowtype
  TU3
 You might have even fixed this already.  Can't tell till we fix up 10.0.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3722>
