[postgis-tickets] [PostGIS] #3720: geobuf regress error on debbie and winnie
PostGIS trac at osgeo.org
Tue Feb 28 12:56:20 PST 2017
  Reporter:  robe     |      Owner:  Björn Harrtell
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  2.3.x
Resolution:           |   Keywords:
Comment (by Björn Harrtell):
 Diff result:
 < +++ /var/lib/jenkins/workspace/postgis/tmp/2_4_pg9.6w64/test_117_out
 2017-02-26 18:41:54.722689185 +0000
 2017-02-28 20:46:04.812781870 +0000
 I.e. only time differs... Should mean this is no accidental memory garbage
 problem. Also means I have no clue what is causing this strange output. It
 does not even look base64 encoded.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3720#comment:16>
