[postgis-tickets] [PostGIS] #3720: geobuf regress error on debbie and winnie
PostGIS trac at osgeo.org
Tue Feb 28 12:52:24 PST 2017
  Reporter:  robe     |      Owner:  Björn Harrtell
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.4.0
 Component:  postgis  |    Version:  2.3.x
Resolution:           |   Keywords:
Comment (by Björn Harrtell):
 Ok so I got a new build from Debbie just now, still erroring. The output
 is:
 geobuf .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_4_pg9.6w64/test_117_diff)
 --- geobuf_expected     2017-02-26 18:37:40.110686758 +0000
 +++ /var/lib/jenkins/workspace/postgis/tmp/2_4_pg9.6w64/test_117_out
 2017-02-28 20:46:04.812781870 +0000
 @@ -3,9 +3,18 @@
 dF9mbG9hdBgAIjoKOAoICAIaBAICAgJqBgoEdGVzdGoCGAFqAiABagUKAzEuMWoJEZqZmZmZmfE/
  cgoAAAEBAgIDAwQE
  T3|GAAiEAoOCgwIBBoIAAAAAgIAAAE=
 -T4|GAAiHAoaChgIBBICBAQaEAAAAAoKAAAJAgIAAgIAAAE=
 +T4|GAAirwEKrAEKqQEIBBICBAQaoAH///////////8B////////////Af///////////wH/////////
 +//8B////////////Af///////////wH///////////8B////////////Af///////////wH/////
 +//////8B////////////Af///////////wH///////////8B////////////Af///////////wH/
 +//////////8B
  T5|GAAiEAoOCgwIARoIFFA8EycTFBM=
 -T6|GAAiGgoYChYIAxICAwQaDhQUFBQTKFBQExMUExMT
 -T7|GAAiJgokCiIIBRIGAgEDAgUDGhZQUCcKMh0oRhMJACcoCR4ePCgTCQAU
 +T6|GAAimwEKmAEKlQEIAxICAwQajAH///////////8B////////////Af///////////wH/////////
 +//////8B////////////Af///////////wH///////////8B////////////AQ==
 +T7|GAAi7wEK7AEK6QEIBRIGAgEDAgUDGtwB////////////Af///////////wH///////////8B////
 +////////Af///////////wH///////////8B////////////Af///////////wH///////////8B
 +////////////Af///////////wH///////////8B////////////Af///////////wH/////////
 +//////8B////////////AQ==
  T8|GAAiGAoWChQIBiIGCAAaAggMIggIAhoECAwGCA==
  T9|EAMYACILCgkKBwgAGgMCBAY=
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3720#comment:15>
